Massive audio
Old 02-18-2020, 11:05 AM
cshocker's Avatar
cshocker
cshocker is offline
Originally Posted by mikes300
how do these numbers equate to actual sound quality? or do they, it just seems like all power is not created equal.
I did some listening with gains set just below distortion (with DD1) and gains set at rated max (with multimeter).
It was definitely a lot louder. It did get a little distorted at max volume. So sound quality wasn't as good when using max. My biggest concern is running a distorted signal all the time (even if I can't hear it) and burning out voice coils or something else on my speakers.
  #72
Old 02-18-2020, 11:37 AM
mikes300's Avatar
mikes300
mikes300 is offline
ya that's what I was getting at, i see a lot of talk about amp cost and big watts but rarely does anyone mention quality, my thinking is the amp is the engine running everything, if its not good no speaker is going to live up to its potential.
  #73
Old 02-18-2020, 02:11 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
Just talked to the contact at Massive.
The information I had sent him has been forwarded to the engineering department for further review.
I was told that I should receive information later today or tomorrow.
Let the under rated amp saga continue
GLIDER 89 (02-18-2020)
  #74
Old 02-18-2020, 02:14 PM
cshocker's Avatar
cshocker
cshocker is offline
I am impatiently waiting for a response from the engineer that my email was forwarded to!
  #75
Old 02-18-2020, 02:18 PM
boosted20v's Avatar
boosted20v
boosted20v is offline
So for my education if your gains are set below distortion per the multi-meter how would you still be sending a distorted signal to the speakers?
  #76
Old 02-18-2020, 02:20 PM
boosted20v's Avatar
boosted20v
Originally Posted by Babyboy
Gotcha
Just woundering with the issues that have came up with the Massive amps that you may have bench tested it before going thru all the labor of the install
my bikes been apart for a couple months now just waiting for me to get around to the install. Hell the amp has been sitting on top of the headlight for that long. Haven't buttoned anything up yet so I can make changes if need be.
  #77
Old 02-18-2020, 02:22 PM
cshocker's Avatar
cshocker
cshocker is offline
I am able to set the gains below distortion only by using my DD1 (which gets me at about 145 watts)
I set the gains just with the multi-meter to get 200 watts
  #78
Old 02-18-2020, 02:47 PM
ScreamingSkulls's Avatar
ScreamingSkulls
ScreamingSkulls is offline
I run a TX48 and BLX4....Cumof sumyoung guy built my amps so I don't have any complaints but I'm not techy **** like you guys (and that is not an insult...lol).
  #79
Old 02-18-2020, 02:55 PM
boosted20v's Avatar
boosted20v
Ok so you set the gains on the amp with a MM then further set them using your DD1. I've got a lot to learn on these DSP's, just added a Dayton to my setup.
  #80
Old 02-18-2020, 03:03 PM
regrol1970's Avatar
regrol1970
regrol1970 is offline
Massive Audio? I thought I seen it listed next to Boss Audio, and Audio vox. Same packaging, bigger price tag! Don't forget the MMATS!
Carizma (02-22-2020)
Quick Reply: Massive audio
