09 Ultra Upgrade
#41
I left my switches in place because they still work in my case. I had Iron Cross install front and rear preamp outputs on my head unit so I could still use the intercom/headsets and CB. I didn't have any clearance issues at all regarding the switches and wiring.
The CB module was an installable option so as far as I know there shouldn't be any problem unplugging it and setting it aside. That should make some room under the fairing for other goodies. I kept mine wired up I just put it underneath the head unit to make room for the amp. if you get creative there are lots of spots in there you can hide stuff. Under my fairing I have an Arc Moto 600.4 amp, an Arc PSM DSP, Metra SaddleTramp bluetooth module, CB module, GPS power supply, two PAC SNI-1 ground loop isolators, a PAC TR-4 remote turn on module, and sound deadening material on the inside of the outer fairing.
#42
#43
#44
I got those too.
Did you leave the rear volume and speaker wire in place? I was going to keep them in place in case I ever pull the amp and go back to stock.
Is there anything in the CB harness that requires the CB to be connected? I never use it and would like to store it.
Not sure on the CB module, but should be easy enough to unplug it and see if everything still works.
#45
#46
#47
Looking good Tsheff. If you ever want to be able to select and control your Bluetooth using the handlebar controls the Metra SaddleTramp bluetooth module is very easy to install on those head units. I like mine a lot. If I am streaming Pandora or I-Heart or whatever and don't like the song I can skip it with my thumb controls. Also I can pause it and put it into random play using the buttons on the head unit.
P.S. I forgot to mention that my setup is so packed that I had to take the circuit board out of the Metra box and insulate it to get it to fit.
#48
#50
I've got several disc burned, just easier to organize plalist and change on the fly. I have been leaving a CD in and MP3 plugged in and alternating as I get bored.
mark10
08-11-2009 03:23 PM
