Leaving Anything on the Table?
Ok since my Batwing thread has had no participation I thought I would try another thread. I'm I leaving anything on the table with my current setup?
Below is what I have installed and a couple of other items sitting on the shelf. Do I bridge the MMats amp for the fairing speakers and add a second amp (possible the JLA Bridged) for the lowers? If I want to swap speakers in the lowers should I put in another set of MMats in that position to keep up with the fairing? Other recommendations on speakers to go with the MMats? Should I add a DSP if I use the QZ yellow baskets?
In my opinion you’re not leaving much on the table. Those MmatsCX in the fairing really can’t take much more than about 150-160, even then a careful tune is needed. Same for the polks.
If you want more then my unprofessional opinion would be to bridge the Jl to the mmats in the fairing. Then replace the lowers with a good midrange and bridge the 4110 to those.
gerby151 (01-19-2020)
Bluesman280 (01-19-2020)
Thanks for the reply. Since you are relatively close to me do you have either of those in the lowers of something I could hear? I would like to make more deliberate steps in the next progression of my build. I will also be in Daytona towards the end of bikeweek so I am also planning to hit some of the bike audio comps to see what a real system sounds like :-)
Randy
Thanks,
Randy
If you already have the MD4110, you may be better suited to run an 8 ohm speaker and bridge that amp to get some more power out of it.
I would get rid of the Polk, I am not an MMATS fan but they are way better than Polk.
The JL bridged to the GZ should sound good. Tuning on everything will be key!
Ndfastin,
Randy
Randy
