I just installed a stinger 700 and Kappas. I am looking at doing speakers in lowers. Would a 6.5 midbass warm up things? The Kappas are screaming at me. I also am using BT355.
if you can afford it, you might try to replace the kappas with the Mmats pa601.4 cx and see if that's enough, if you want a little more add the same to your lowers.
m
If it were me, I'd put a warmer speaker in the fairing and put the Kappa in the lower. Maybe a PA601CX in the fairing crossed at 100-110. The Kappa will still be loud from the lower and not melt your face.
These, correct? And is there another better than MMats Coax 6.5".
Yes there is a bunch of stuff that's better, just depends what ur budget is and how much ur willing to do for a fairing install other than 4 screws per speaker.
T
I would be looking for good 6.5s that dont have cross over boxes. No cutting up the inner for me. I'll prolly try the Mmats.
