Amp suggestions for this setup
Thanks for sharing C_Man!!! Can u provide some info on the specific amp ohm and speaker ohms as u wired them bridged & parallel. This bridged parallel thing is fairly new for folks plus the varying SD amp ohms are causing some helmet fires.
Thanks again for sharing!!!
T
T
4 4ohm horns to SD 250.1 2ohm w 1 ohm load
Faital and Prv are 8ohm bridged parallel to SD 800.4 4 ohm
The 10s are 8 ohm parallel to Prv Am1h 2 ohm mono amplifier
Originally Posted by c_mancuyas8
Haha yeah I should've clarified
Thanks again!!!
T
Thought I'd update this in case someone goes searching so they can see an end result. Here's how it ended up.
And a big thanks to Adenton!
Dayton dsp
SD 250- horns
SD 800.4 bridged- faital 6rs140 fairing prv6mr500 lowers
Prv Am1h - forte 10s bags
Dayton dsp
SD 250- horns
