Batwing fairing stereo speaker upgrade
That is a full size single din, you can pretty much add any single din you like that has all the features your looking for in a radio. Most people like the Kenwood decks and they should have what you want. You will not need and adapter just some Rca's to get input into an aftermarket amp. You will have to run power and ground to the battery, a remote turn on wire from the deck to the amp, and run some speaker wire from the amp to your fairing speakers and to the bags if that is where your other speakers are.
Pretty easy to do!
is there a way to cut or grind the fairing so you can add 6.5" speakers ?
Juice
Pretty easy to do!
Juice
so is the output converter for older stereos or something ?
Yes makes sense thank you . The speakers you put are the saddlebags ones right ? So it's really speakers -headunit-rca-amp-speaker wire-speakers ?
Originally Posted by miketv84
nothing yet
Ok I'll give this a shot. I run a Reckless fairing on my wife's Heritage. I'm running 4- 5.25" (4ohm) Kickers in the fairing, a set of 6x9's (4ohm) in the lids, and a 4ch amp. Left fairing speakers are paralleled to 2ohms and ran on channel 1, right fairing speakers are paralleled and are on channel 2. 6x9's are on their own channel on 3&4. 2-1.5' RCA cables go from radio to amp and speaker wires from amp to speakers. Power source for radio is ran to a fuse in the fuse panel that has switched power. Yellow wire from radio will need constant power. Additional power and ground will need to be ran for amp.
