2 channel amp for Mmats PA601.cx
#31
Another option https://nvx.com/vadm2/
I have the 4 channel version and once I turned it, it's been pretty awesome.
#32
If that fairing is typical of most 4x5.25 fairings you should be able to fit 2 6x9's in there easily. In which case I would recommend 2 MMats 690.4CX's, unless you don't like the look of 6x9's there. Otherwise most any 6.5 and bullet horn should fit with room to spare. The smaller Dyna sized fairings can be a little tight with some 6.5s but even then most will fit. For an amp on a budget look at the Cerwin Vega B52. It's plenty of power for 2 6.5's or 6x9's, small and affordable.
#33
#34
Well I figured the Stinger 350 is 5.11" wide, the Massive TX48 is 10.75" wide. On an aftermarket fairing on a Road King that sounds like a big difference in size.
123Ozzie sorry I didn't dig into the problem with the gains set too low very much. I figured I was having to turn the volume up on the head unit so high that the output was starting to distort. The amps would actually go into protection mode because they sensed distortion in the speakers I guess. When I turned the gains back up a tad the problem went away and never came back.
Thanks. I have a Stinger 700 on my bike and when I tear it down this winter, I'm going to play around with bridging it and turning the gains down. I'm curious what the results will be.
#35
Bluesman280 (12-04-2019)
#36
#40
