Boom GTS upgrade kit for 18 and down
#141
I've finally gotten the fade to work! Long story short, after sending my amp in twice for repare only for it to come back and no problem found, RF replaced my amp with a refurbished unit, but still the problem continued. Called tech support and we went over all of the connectors and connections. Turns out the Bypass adapter in the original amp plug was not the correct one for CVO's. He sent me a new adapter with a connector that gets plugged into the rear output port of the amp which fixed the problem. My question is why did if work before I swapped the radios? I hate to think it but my only guess is when I took the bike to get it flashed, they swapped plugs on me. Thanks for all the help ya'll given during this process. I wanted to let you know the outcome.
