No sound
No sound
Few weeks back, out on a ride and after about 1 hour the radio stopped. Went back home and then the next day I tried the radio again and it worked. Today again on a ride and the radio stopped again, then stopped for coffee and after about 20 minutes went to start the bike and was completely dead. After about 2 hours went back and everything started.
Any ideas as to why the radio stops and then that prevent trike from starting.
2012 Harley Trike
2012 Harley Trike
Sounds like it is working like it should. In all seriousness that is a common problem with the Harley HK radios. Iron cross can fix it and upgrade it with goodies or you can buy another ticking bomb.
http://www.ironcrossaudio.com/
Originally Posted by SBates08
Pretty sure whatever is causing your bike to not start is not the radio. I'd be checking for loose grounds or a battery load test. Once you find that culprit, bets are everything goes back to working as it should.
T
2012 Harley Trike
2012 Harley Trike
