tuning 6.5 sealed back
trying to tune eminence Alpha-6cbmra in my lids, running approx. 150 watts each, they have a frequency range of 400 to 5000hz, been at it the last 2 days and just cant quite get it.
here is a screen shot of where I left off, can someone chime in and help with adjustments, please feel free to pick the tune apart as i'm very new at this dsp stuff and can use all the help possible, thanks in advance.
madhunter60 (10-23-2019)
in addition to what Juice said, maybe turn down the wattage a bit and widen your frequency range. that is a general spec and it does not mean that the speaker cant/or wont play at a wider spread. turn down the power and set your high pass up around 100 and experiment. do this at reduced power levels and see how it sounds, if it sounds good increase the power and tweek as you go.
themizz
Fuel Moto / Jackpot Mufflers
02-22-2014 02:15 PM
