96-13 batwing bikes DSP cable
09-30-2019, 06:21 PM
Where do guys route the cable on the older bikes? Hopefully there's a way to do it not to have to remove the fairing every time?
09-30-2019, 06:27 PM
I went thru the clutch cable hole and put a cover on the end of the cable. Then bought another cable to plug into that one to go to the laptop.
09-30-2019, 06:30 PM
That's what I needed, thanks Bates!
09-30-2019, 07:34 PM
I have a triple bag that sets on the inner fairing, I drilled a hole through both and leave the excess cable in the triple bag.
09-30-2019, 08:08 PM
You can also use a cable extension to run it underneath the seat
10-04-2019, 06:10 PM
I just came down the steering neck on the clutch side and put a weatherproof cap on the end.
10-04-2019, 09:15 PM
Thanks for the ideas everyone We will try a couple options to decide.
10-05-2019, 07:39 AM
Originally Posted by
marshallb
If you go the extension route, heat shrink the coupling!
Juice
10-05-2019, 01:59 PM
I'll definitely remember to do that
keith t
04-20-2016 10:05 AM
06SGWA
07-25-2013 04:12 PM
Geezer glider
06-27-2011 09:57 PM
lowlife801
Shovelhead
02-25-2010 05:45 PM
BiggestDawg
07-07-2005 01:15 AM
