Metra Double Dim Fairing
I’ve had the privilege of doing it twice. I broke the first one bolting it up due to alignment issues. The second one worked better but still was painful. After some time in the heat the figment didn’t get better.
Quality and finish are good, the fitment was an issue. having CarPlay makes it worth it. In the end I’m happy but it took longer than I expected to get it done right.
It’s definitely not perfect but I also added the wind deflectors to it. I think without the deflectors the heat and tension would eventually line it all back up. I have a small gap 1/16 or less on each side where it rounds. I use black caulk to fill it. Nobody has ever noticed it, but as the installer I’ll always know it’s there.
It changes the angle of the speakers as well. It required a bit of tuning to get it back to the same level sound as the original. Overall I don’t regret it but while I was doing it I wouldn’t have wished the install on my worst enemy.
If you want Car Play or Android Auto it’s about the only way to do it. For me it was worth it but I worked hard to get it. I also upgraded to the painted inner so the look of the gloss black was a significant improvement.
If I could do it all over again, I’d bolt the inner and outer together off the bike with nothing installed and let them back in the sun all day to shape then do the install. I did mine in the winter when it was cold and think that played a large part in my troubles. I’d likely give up the deflectors too, but I really like the look on my bike.
