Amp question
Amp question
Hey all, A while back i talked with tailwind about a set up for my 17 SGS. 6 speaker set up faring,lowers,tp.I have all the speaker's that we talked about. The Db wdx6moto g2s 4- Mmat 601cxs. So heres were im stuck, we talked and i was going to use the focal sport amp. But i got hurt at work and cant swing that amp at this time. My question is can i run 2 stringer amps temporarily in the batwing tell i get back to work? Im not sure if they both will fit. Also will i need 2 more bt line levelers if this can be done... Thanks a ton for your help on this.. Also a shout out to tw for taking his time to help me out with the original build..
Have a peek at the Massive Audio TX48. Run the fairing w CX in parallel on channel 1. Run the CX TP in parallel on channel 2. Run the Motos on channel 3/4.
Lots of combos possible but that amp should get u 170 or better to each of the 6 speakers regardless of the location and wiring plan.
4x400@2ohm
4x200@4ohm
T
I would run the left fairing and left tp on channel 1 and the right fairing and tp on channel 2 to give you left to right stereo instead of front to back stereo if it were me. No fade front to rear but retain left/right stereo. But that’s just me. Sorry to hear you got injured at work man. I hope you recover quickly. You won’t need any more line levelers if you use another amp as you can use a rca splitter out of the line leveler to feed both amps.
All jokes aside that thing looks to be the same size as the PN4.1000d with more power. Do you know if it would be a problem with the charging systems of older bikes? That thing could definitely be a contender for a saddlebag mount if someone didn't mind sacrificing the space.
VERY impressive looking hunk of metal.
Originally Posted by Hoyt 1911A1
Holy Cow T, that Massive Audio amp looks like a beast. I wonder if it would kill the FM reception of the guy riding next to me?
I have mine sitting on the JM amp tray with no dimension issues. Room to spare.
It's still early in the game but this amp really is damn nice regarding watts and the SQ is pretty damn good so far. 200x4 @ 4 is never a bad place to be.
T
AndyinTally
Audio Systems
01-28-2014 04:16 PM
