8ohm speaker wiring.
GODDDAMMIT I gave all the specs did you read the post hahah. The two channels bridged are 500@4ohm and yes bridges and parralleled
To my understanding and calculations a 4 ohm load (2 8ohm speakers parallel) at 500 watts is 44.7 volts output. Giving each speaker 250 watts.
Now since the speakers are 8ohm the speakers will use half of the 250 watts that the amp is putting out reducing the output again by half giving them 125 watts each.
Is my thinking and calculations correct?? If they are incorrect please correct me and explain how you come up with your figures.
I'm just trying to clear up a very muddy situation that confuses the **** out of alot of people.
Edit/add
500w @ 4 ohm load = 500 watts output to speaker
500w to 1- 8 ohm load. = 250 watt output to speaker
500w to 2-8 ohm loads =125 each
Edit/add
Edit/add
Edit/add
If you wire in parallel you end up giving the amp a 4ohm load which means the amp produces 500watts. Those 500 then get split between what is on that wire ( 2 8ohm speakers) giving each 250
