Bridging Speakers, amps,etc........
Old 09-19-2019, 08:20 AM
Eric Steward's Avatar
Eric Steward
Eric Steward is offline
Default Bridging Speakers, amps,etc........
Hello,
I always see people posting comments about bridging speakers. Then when I look google "bridging speakers" it always talk about bridging Subs or just one speaker. So, My question is : how are people bridging their speakers in the fairing and so on.With a four channel amp and trying to bridge the fairing, where does that leave the lower fairing speakers?
Also, when people talk about supplying more voltage to the amp or speakers, how is that done?
Old 09-19-2019, 08:37 AM
rgsboogie's Avatar
rgsboogie
rgsboogie is offline
What amp and speakers are you using?
Old 09-19-2019, 09:23 AM
travelingypsye's Avatar
travelingypsye
travelingypsye is offline
^^^^^What he said^^^^^^
Depending on just what amp and what speakers you are running you may not need to bridge your amp.
Old 09-19-2019, 10:35 AM
yooperhog's Avatar
yooperhog
yooperhog is offline
Rockford Fosgate DSR-1 ,Sony XAV-AX 5000- Arc 600.4 in the faring along with Hertz Mille Pro 6.5 upper fairing. the lower fair has Moto 602's 6.5 mid-bass speakers parallel with JL 6.5 ( C2- 650 ) in TP, NVX 1000.4 amp in TP connected to (Hertz Mille Pro 6x9) in lids and JL audio 6x9 (c2-690-xt) inside the bags.
This is what is listed as his equip
Old 09-19-2019, 11:35 AM
Eric Steward
This would be correct. Not to say I wanted to do that, but how are people doing it is what I don't understand. this may be something I could look at in the fall.....
Old 09-19-2019, 05:44 PM
memphisharley's Avatar
memphisharley
memphisharley is offline
Veteran: Marine Corp
I would like to know when to bridge and when not to bridge. but I gather it depends on the setup.
Old 09-19-2019, 06:19 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
Guys that are bridging amps in their setups, planned out their setups beforehand with this in mind. It's not something you can just decide to do one day to your 8-10 speaker system without completely re-evaluating your amp to speaker setup.
Mike-81 (09-20-2019)
Old 09-19-2019, 07:37 PM
Juice's Avatar
Juice
Juice is offline
You need the right speaker resistance and the right amp to handle that resistance when bridged.
This comes into play especially with the SD amps.
That 800.4 (2ohm)
If you hook up (4) 4ohm speakers, you are getting 61 watts each. So 244 watts out of 800 possible..Not good..
But if you wire (2) 4ohm speakers in parallel and run that amp bridged you get 200 watts per speaker in mono vs stereo.
Look at the red dot ratings.
This is why SBates said to plan this out, or you will have mismatched gear and leave alot of power on the table.
Juice
The following 2 users liked this post by Juice:
Eric Steward (09-19-2019), Mike-81 (09-20-2019)
Old 09-19-2019, 07:51 PM
Eric Steward
Originally Posted by Eric Steward
Hello,
That 800.4 (2ohm)
Juice
I was just wondering, Hey guys. thanks for the information.
Old 09-20-2019, 05:06 AM
Eric Steward
Let make see if I understand this concept.
SO for example, of I was was to run my Arc in bridge mode j would parallel the fairing speakers both upper and lower ,upper on 1&2, lower 3&4 .that would be 300 and 300 for a total of six hundred. Well the arc is 150 par channel anyway, so what is the difference? Just trying to figure out when and with not too.
Quick Reply: Bridging Speakers, amps,etc........
