Sound deadening
Old 09-09-2019, 12:01 PM
GunslingersNation1's Avatar
GunslingersNation1
GunslingersNation1 is offline
Default Sound deadening
Riding to work today, my front fairing sounded "hollow" . I am assuming this is because of the bt brackets, but I could be wrong. I have dynamat in the fairing, but can I put more in to try to keep the waves coming straight out?
Old 09-09-2019, 12:22 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hoyt 1911A1 is offline
Some of us have had a little bit of success putting polyfill around the speakers. To me that helped a tiny bit with this issue. If you try that and it doesn't help maybe tinker with your tune on those channels a bit. I can't remember, are you using a DSP?
Old 09-09-2019, 12:50 PM
GunslingersNation1
Yes, a dsr1.
Old 09-09-2019, 01:33 PM
GunslingersNation1
Maybe I'll try some of those Fast Rings.
Old 09-09-2019, 02:34 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Did u use the backer rod that came w the BT brackets?
Did u get spacers & bolt the inner fairing to the BT brackets to stabilize the entire fairing?
T
Old 09-09-2019, 03:47 PM
GunslingersNation1
T
Yes to both. The backer rod is taped in and I broke the first set of bolts and BT had to send me another set. And, the j&m tray is bolted to the brackets.
Old 09-09-2019, 04:18 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
What specific bolts are u talking about? I don't think BT provides spacers & bolts for the inner fairing attachment.
T
Old 09-09-2019, 04:41 PM
GunslingersNation1
T
The standoffs for the lower two bolts to the fairing.
Old 09-09-2019, 09:32 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Then ur missing one bolt on each side and they are located up near the upper outside gauges. 1/4 20 and about an inch and 1/2 and also some nylon spacers u can grind to fit perfectly. It really tightens up that inner fairing.
Not sure if it's gonna tighten up ur sound too much but it sure as hell tightens up that inner fairing from rattling around like a ****.
The holes are pre-drilled in the BT bracket so have a peek the next time u pop the hood.
T
Old 09-10-2019, 05:15 AM
GunslingersNation1
I do have those. I remembered when you said nylon spacers. Yes, they are in.
Quick Reply: Sound deadening
