Stinger SPX700/4 4 ohm Rating?? 100watts or 125watts
I was looking at the Stinger or the Mmats. All the reviews here say they’re both great amps. Stinger a little more power, the MMATS a little better SQ.
Going back and forth between the two, more power, better SQ, more power… So my defining factor was the water protection. The Rushmore bat wing fairing vent is not water tight and water can drop on top of an amp sitting on top of the radio. It may be only a small amount but still worried me so I went with the Stinger for the better water protection (by description) and the additional 15 watts would just be a bonus.
The web and forums like this make for so much research before people buy it make my head spin. And I read a butt load of stuff …
Thanks for all the comments.
Gambat
- Stinger water protection rating IPX-4/5 weather-resistant design: IPX4> water splashes from any angle / IPX5> water jets projected by a nozzle (6.3mm) from any directions
- MMATS: Our marinizing process allows MMATS products to function in moderately damp environments but they may never be submerged or be in direct contact with water.
Gambat
Its going in a 14 Limited.
Teedoof65 - Have Mmats PA601CX coming for the fairing and TP.
Travelingypsye - The front access was a big selling point too.
My first stab at this was based like a lot of others, on a budget. The guys here helped me put together a good budget system. And it was loud and clear like they said. Bright but clear. Some songs the vocals were piercing. Now I read about newer speakers sounding fuller/warmer and it gets me thinking, Now I can afford better speakers so. I'm NOT trying to building a competition system at all but the new PA speakers that are out made me want to try them. Again reviews are all I really have to go by so hopefully my ears and what I expect from my musical SQ are similar.. Not expecting to feel heavy bass but looking for a fuller/warmer SQ. If that's my unicorn cool.. Like Dee Snyder said "I just want to ROCK"...
Gambat
Gambat
Gambat
Do you have any pictures of your install? I am planning on doing about the same install as you, and would like to see/know how your installation went.
I too am flipping a coin between the Stinger AMP and the Mmats Amp. The easy of install would and does help me want to lean more towards the Stinger Amp.
I would like to see how your speakers mount into your wing and do they take any mods to fit either in the front wing or TP....
Gambat
Gambat
It's not just about watts. Clean watts and speaker efficiency matter too. The Stinger is a proven performer. There is a reason they are so popular on this site. Start looking through the builds on here. You will find it being used in a large percentage of the builds and lots of happy bikers.
I can’t comment on the Batwing as I am a Road Glide snob but I can tell you that you will be needing a large spacer or the Vtwin Audio tour pack adaptors to fit the MMats coax in the Rushmore tour pack pods. I chose the adaptors for the much better look. It was worth the extra cash for me.
Gambat (08-12-2019)
