CV B52 died
If riding at 40mph at 3/4 volume and you accelerate to 70mph, your are now going past your amp installed max volume. Essentially overdriving the speakers and introducing distortion.
Son of a b*tch. Installed new amp, same thing, won't turn on. Remote wire for amp shows zero volts when head unit is off, check. Shows 1.5 volts when I turn it on, so I figured it was working ok.
But since the new amp won't turn on either, I run a jumper from the headlight plug. Turn key to on, voila amp turns on, 12.8 volts on jumper. So my problem was never the amp, it was the remote signal from the head unit, low voltage.
I remember on one of my old setups I was getting a whining noise from the speakers when using the headlight as a amp turn on signal. Will have to try it out.
Jim
Jim
Jim
Jim
T
Well, you're obviously not a smoker!!!!! Lol
