New Amp/ Speakers on 2003 Electra Glide
First of all, what head unit are you running? As others have stated, the hog tunes stuff just isn't as good as stated so send it back. If running a stock head unit, I would consider upgrading it to aftermarket as that alone will provide a better SQ to your setup regardless of amp and speakers. If running stock head unit, upgrade it to a sony mex 100bt as that has 5v preouts for better SQ. A good amp is next. If you EVER plan on adding lowers or rear lid speakers then buy a good 4 channel amp to start with and be done with an amp. A cv b-52 is only a 2 channel amp and wont provide any future expansion. A vadm4 is a solid little amp but not powerful enough for a 4 channel setup. Spend a bit more for a stinger or mmats 4110 to begin with and you wont need to upgrade the amp later on. WDX gen 2 or mmats pa601cx speakers with either amp mentioned above will provide a solid warm sound that gets loud. Spend a bit more to begin with and no need to upgrade later. Nothing wrong with what has been suggested but as stated, this stuff can get addicting real fast and I have seen guys upgrading amps left and right. In my experience, just get the amp and head unit needed for future to begin with and be done.
The amps I recommended will get you through a 2 speaker system, but 4 or 6 speakers is always better than 2, lol. Grab a Stinger or Mmats 4110 right off the start, and then your ready for lowers or speaker lids when you decide to add a little more. I am really glad I added lowers, but you need the right speaker in there to hear them.
Rock on and play it LOUD!!!!
Originally Posted by Adeezy9183
Sure I’ll sell it. Shoot me an email @ Andrew_demory@yahoo.com
