Sound dampening in batwing
Biketronics is working on an aperiodic enclosure to go along with the adapters. I have a set being shipped to me now. I have the issue with sound of the 7.1 pro in my fairing. When first installed I did not fit the foam around the front of the speakers. That helped a bit and the covered the inside with dynamat extreme. That helped a bit too. I’ll report back once I ge the enclosures installed.
[img]blob:https://www.hdforums.com/bb52742c-8924-47e0-a7fb-3ebd5633dbcf[/img]
When UltraNutz was the audio guru here a while back the suggestion was made to put poly fill over the speakers and wire tie it to the speaker frame. I did that and it made a world of difference. I think what it did was keep the sound from bouncing around inside the fairing
I just put some polyfil around the 7.1's in the fairing. My lowers are a different story. It seems the speakers are open to the elements on the bottom. I don't recall if this was the same on my 16 SGS. I purchased Harley lowers and pods, installed but there isn't anything under the speaker to block rain/mist nor dampen the sound. Any remedies out there? I can stuff polyfil up there I guess.
[img]blob:https://www.hdforums.com/bb52742c-89...b-3ebd5633dbcf
