What amp after a DA 4v2?
I am running a Diamond Audio 4v2 with a pair of HERTZ HCX 165 in the fairing. I had bridged the amp previously but kept blowing the speakers as pushing 300w a channel and speakers were rated at 200....opps.
I have now reconfigured my amp and running the speakers at stock output i.e. 80 watts a channel (4 ohms), but damn it I am missing the volume
Guess I have a few options:
1) Change amp to one with a higher output for 2 channel - however might add extra speakers at a later date so 4 channel amp would be better
2) Re-Bridge amp and buy higher output speakers - Not sure which ones?
3) Buy 2 ohm speakers which my existing amp would push more power to 150watts = louder
Recommendations please
I have crossover set as flat
Is there something I am missing, I am no audio expert.
The speakers was Ok before, but if I cranked the head unit up, even for short time it blew speakers ;(
You can run a 1000hz test tone and hook a meter to the amp outputs with hu volume at 3/4 (no speakers hooked up). Follow the chart in the sticky to determine watts. Amp output is in AC volts.
https://www.hdforums.com/forum/audio...ier-gains.html
I only know how to see the gains for maximum efficiently, i.e turn head unit up to about ¾ , 3 makers on right not taken, then slowly increase gain until distortion is heard and then back off a little.
