2019 Electra Glide Standard/Radio
The kit will come with the mounting bracket including the pieces to fill those gaps. With $1000ish you can do a descent 2 speaker set up. You should be around $450 for the Sony, $50 for amp wiring, that will leave you about $500 for speakers and an amp. Read a few posts around here and you should get an idea of what to buy. I chose to do a full MMats setup and you should be able to do their amp and 2 of their coax speakers for $5-600.
eggwhite93 (05-30-2019)
Stock radio install electra glide standard.
I ended up putting a radio in my 2019 electra glide standard. It's actually pretty simple to do. I ended up going with a 2018 boom 4.3 and 2016 street glide speakers. Other additional items that were required. Were 2 speaker wire connectors and the left hand control to turn the radio up. Everything was plug and play. If you Ebay search like I did. I did mine for around 400 dollars.
Been reading the audio section for a few days and have come up with some ideas for radio in my 2019 EG Standard. I only listen to classic rock/rb from usb stick. Don't need am/fm or phone interface unless maybe pandora on phone. Let me know if I'm on the right track or... Thanks
HU - Sony DSX-M55BT
Amp - Soundstream PN4.1000D
Fairing Speakers - Infinity Kappa 62ix
Lower Fairing Speakers - Mmat PA601-4
Hogtunes grilles - Fairing pair and Pod pair for lowers
Ebay speaker boxes for lowers - Matte black
Waterproof cover -
Won't need any dash kit, I can fab acrylic front plate and fit to stock glovebox. Installed car stereo for a living in the late 70's.
Won't need wiring kit, I can identify switched and full power to connect. Make up heavy pos/grd for amp to battery myself.
I may not install amp right away to see if sound is full enough for highway. I can do all this for less than $500, less than $400 without amp.
Appreciate ANY input from gurus here!! Thanks!
HU - Sony DSX-M55BT
Waterproof cover -
