I purchased the sony ax5000 and metra inner fairing to upgrade 2011 tri-glide. kit came with fairing,ax5000, control module/wiring connector for hand controls ,but no wiring harness for adapting hd 35pin connector to ax5000. any advice would be appreciated.
You will only be using the 1 connector from the brake side of the headunit. The connection on the clutch side is for the intercom,CB,rear controls which will no longer be needed or functional.
