6th Gear Indicator & Cruise Control
Just yesterday my 6th gear indicator and cruise started going on at off at same time. From what I read it's the clutch switch in the handlebar housing. It starts in gear with clutch in but it trys to lunge forward but doesn't actually move. I was just looking for confirmation before I tore into it. Also can I short out the switch to get cruise and 6th indicator back working? I assume then my bike could possibly start in gear. I was a little confused cause my radio display was also off and on but not same time as 6th indicator and cruise. I had just had Iron Cross rebuild my radio over winter so I thought I was done with radio issues. Guess not. Display would go out but the clock did not go back to 12:00 so I assume it wasn't losing power. Also the AUX Jack sounds horrible. Tried multiple cords and IPods and was muffled and low volume. Thank you for your help! Bryan.
tbagozzi
2014-2023 Touring Models
05-22-2016 05:20 PM
freedom_ride
09-29-2011 07:02 AM
