BOOM Box iPod Classic Infotainment Q:
--2019 FLHTK--
Does anyone know if there is a way to connect a straight audio input into the head unit? I realize there is no provided input jack available, but does the head unit have an input that can be tapped into? On the surface it seems to accept only a bluetooth input or USB.
I tried connecting my iPod Classic into the USB and it said the device is "no longer supported". Frustrated, I'm looking for a direct audio input solution for my non-bluetooth iPod.
Thanks!
Thanks!
I still would like to know if anyone is aware of an audio input to the Boom Box HU before dismantling the fairing just to take a look. If I can get that hooked up, then I just need a short audio cord for the iPod Classic. Playlist takes care of the rest.
On the 18 down bikes. HD sold a 3.5mm adapter that plugged into the factory harness. The dealer then used their DigiTech to enable the auxiliary port and it would show up in the media menu.
I know the 19's use the GTS head unit now, but the wiring looms appear to be the same. You may want to check with your dealer to see if this adapter works on the 19's.
RD335 (05-05-2019)
So if the HU itself is not compatible with let's say iPhone 5 and older and also Classic iPods & Gen 5 and older Nanos, how does a direct connect thru an aux change the fact that the HU no likey the above mentioned Apple products? Is it the Digitec that puffs up the HU?
I'm pretty damn sure I don't understand the specifics surrounding the OP's question, or the question itself for that matter.
T
T
T I think he just wants to plug up an iPod through the AUX connector, select that input on the head unit, and use the controls on the iPod itself for play, skip, etc. Like we do on the 13 down bikes. The head unit has no idea what exactly is plugged into it, it just routes the audio signal to its outputs.
The audio quality of those older iPods is excellent. They seem to have cut a few corners on some of the newer models. I have several older click wheel iPods and when I plug one into the AUX port and just drop it into one of the pouches behind my windshield it sounds excellent. Much better sound quality than my modern Samsung Galaxy phone.
I'm totally picking up what ur laying down regarding iPod SQ. It's damn good when it's as intended like back in the day. The bigger prob is that will all these modern HUs, most of them are just interfaces for the plug ins thus the source quality is a massive detail!!
T
In my mind it's hard to beat a good old 3.5mm input. For anyone who likes the old iPod simplicity but wants modern storage sizes this dude has a nice upgrade adapter:
iPOD and SDHC – SDXC cards
I like the older click wheel iPods because they can be used easily without fighting with iTunes. There is a free utility called Sharepod that allows you to freely copy music to and from the iPod without the need for synching and such.
All great comments. Connecting the iPod to the USB port resulted in the HU saying it no longer supported the device. So an audio input would allow me to use the iPod with the iPod controls, as we all did in the stone age before bluetooth.
SO - I invested in a small device on Amazon. It plugs into the iPod and transmits bluetooth sound. It has great reviews. I tried it with my home theater and it worked very well. But when I tried to use it with the bike, the dang HU is "unable to pair" with the device!
//RD
