DSR-1 Noise
DSR-1 Noise
Well I finally got my new amps and speakers mounted and wired to the DSR-1. Fired it all up last night and man, I am impressed!! GBA hooked me up with a great map and support, couldn't be happier.... The DSR-1 has taken audio it to an all new level BUT, I now have static (noise) problems.
Are any of you having this with your DSR's? I'm running an SD800 / SD400 with 4 guage wire (hot and ground) coming from battery to separate distribution blocks. One is Power (1 input / 4 outputs) and the other Ground (1 input / 4 outputs). When I wired the DSR I simply ran the power and grounds into the distribution blocks supplying the amps. I then wired the remote (Radio into DSR, DSR out to AMPS). Static remains regardless of gain setting. Obviously it gest louder the higher the gains are set. So what am I doing wrong?
Do I need to rewire the DSR's power or do I have something else going on?
Everything is going to the battery (Pos and Neg). In intial set-up from GBA, they said to set the gains to zero on the amps. Should I leave them at zero or can I adjust? Still trying to learn the nuaincess with this thing but so far, its sweet! Cheers!
Anyway, thanks for feedback!
like t said, keep your rca cables away from the power and ground cables to help with RFI, you could try wiring the power and ground at a different location and see if that helps, you're kinda in a try it and see what works situation. maybe a noise filter on the DSR power supply line.
m
m
I got those rca 10 pack as well. I'm just wondering if you was able to fix the popping problem?
The SD800.4D and SD400.4D are both Class-D amplifiers and known for noisy power supplies. Is the noise constant? Avoid running cables or the antenna near the B+ and GND wires for those amplifiers. If the DSR1 is mounted on top of the amplifiers, this could also cause an issue, so test it by physically moving the DSR1 away from the amplifiers.
__________________
http://www.rockfordfosgate.com
Rockford Fosgate (06-03-2019)
