DSR-1 Noise
How far apart??? My amps are under radio and over the headlight, the DSP is to the right of the of them all. Its not so much of a static noise as it is a loud hissing sound. Did your issue go away completely??
HD Boy (12-18-2020)
HD Boy (12-18-2020)
Did you ever find the correction? I have the same issue with factory 19’ GTS stereo, arc 720, evox 400. I am thinking it has something to do with the DSR because the static/hiss is feeding through all speakers.
Is your bike plugged into a battery tender when you hear the hiss? that has been known to cause a similar problem
HD Boy (12-18-2020)
This is the fix to the popping
Well I finally got my new amps and speakers mounted and wired to the DSR-1. Fired it all up last night and man, I am impressed!! GBA hooked me up with a great map and support, couldn't be happier.... The DSR-1 has taken audio it to an all new level BUT, I now have static (noise) problems.
Are any of you having this with your DSR's? I'm running an SD800 / SD400 with 4 guage wire (hot and ground) coming from battery to separate distribution blocks. One is Power (1 input / 4 outputs) and the other Ground (1 input / 4 outputs). When I wired the DSR I simply ran the power and grounds into the distribution blocks supplying the amps. I then wired the remote (Radio into DSR, DSR out to AMPS). Static remains regardless of gain setting. Obviously it gest louder the higher the gains are set. So what am I doing wrong?
Do I need to rewire the DSR's power or do I have something else going on?
Everything is going to the battery (Pos and Neg). In intial set-up from GBA, they said to set the gains to zero on the amps. Should I leave them at zero or can I adjust? Still trying to learn the nuaincess with this thing but so far, its sweet! Cheers!
Anyway, thanks for feedback!
