Biggest amp frame size
What is the biggest amp frame size that will fit under the fairing of a 2019 sgs without modification? Example. 6.7 W x 1.98 H x 10.7 L . Do you have to get a separate wiring kit to hook up the LOC or do you just tap into the harness? Can you run 2 ohm speakers on channel 1&2 and 4ohm on 3&4 ? Thanks for any help.
J.. i would have to assume on the stock amp tray since j & M would be considered "modification"... but in any case.. NVX is popular now..MMats, Diamond, Soundz, Arc those are 5 off the top of my head that make Amps to sit on that stock amp tray. the question of "largest" is relative... I could give you the largest amp but it still might not fit your needs.... But I do know these are quality amps would fit. In regards to The channel 1 and 2 and 3, 4 question... that depends on your speaker and amp combo.. dont have enough info to give you a good answer... The best on here is to tell us what you are trying to achieve with how many speakers, amps, hu, etc.. then let everyone chime in with suggestions.
Budget install. Just need a little more sound. Have a lot of home projects going and got a new bike, hit an antelope in sept with my ultra limited. Was thinking about this since Tailwind said he liked his Rockville speakers. If the amp is too big I would go with the Soundstream PN 4.1000. Stock tray. Thanks for the help.
Dyna.. yes, your sound will change, the BT355 will make your system sound better...its a line leveler it "levels" your eq from the head unit so when you adjust your amp, etc it will sound alot better.. the pac is a line out converter...two different things ..doubt you will use this.... Tailwind was saying you will need the BT355... 2..if you want to fade...
