Boom AMP with aftermarket Speakers?
My 17 Ultra has the Stage 1 Boom kit on it. I am happy with volume but not happy with the sound, the system is lacking in the bass department.....
I see that the boom stuff is 2ohm but that most aftermarket speakers are 4ohm.
Can I run the 4ohm speakers on a boom amp?
Will it damage the amp?
In time I'll probably replace the boom amp with something better but for now I am just thinking speakers.
Desert Hog (04-11-2019)
Ok, so when I replace the boom amp do I need to get the bikes radio reflashed back to stock because I removed the boom AMP?
Its an Ultra so it already had 4 speakers and front/rear fade prior to the flash after the boom amp install.
Did the flash the dealer did when I installed the boom amp turn the radios outputs to low voltage versus being high voltage before the boom amp reflash?
I'm running 4 ohm dd audio speakers off my boom amps and haven't lost any volume. seeing as how it was mostly distortion at the upper end anyway. plus they're like pa speakers which makes them fairly efficient so you get plenty of sound IMO, BUT you still have the SH!TTY boom eq curve to deal with. but it's gotten me by until i decide how to finish the system off
Desert Hog (04-12-2019)
Desert Hog (04-13-2019)
