2 Channel Bridging Question
04-09-2019, 11:01 AM
Finishing the install of Sony XAV-AX500, SPX700X4, and Arc Moto 602 speakers in my fairing. Currently only running two speakers so going to bridge the amp.
Question - should I bridge it using 2 Mono Outputs and the amp set to 2 Channel or run 2 Stereo Bridged outputs using Y-connectors and set to 4 channel? Same power per speaker, right?
Thanks in advance!
04-09-2019, 11:13 AM
there is no real need to bridge that amp with those speakers. you can try it out either way and see which way sounds best, but if it were me, i would not run it bridged.
m
04-09-2019, 01:05 PM
I would agree with marco as 175 is plenty to those
Bridging based on haze's recommendation. I bought the amp and speakers from him. He advised that the Arc Motos sound best with the higher watts.
04-09-2019, 01:16 PM
I know it’s a video but use headphones. Arc Motos with 170 going to them.
04-09-2019, 01:25 PM
From the specs I see that amp only puts out 125w/channel at 4ohm. I vote bridge in stereo. Just be conservative with the gains.
04-09-2019, 01:28 PM
Quote:
So how is he going to get to 170 watts with this amp @ 4ohms without bridging it?
04-09-2019, 01:30 PM
SBates08
i misread the specs on the amp my apologies. Yes you will need to bridge.
04-09-2019, 01:34 PM
Bridging in stereo it is.
Thanks for the video Frenchie, looking forward to having that kind of sound with the Arc Motos.
04-09-2019, 01:37 PM
northcoastmopar
cool sorry for the confusion as I’m trying to “work” and look up amp specs haha
