DSR! help
DSR! help
Sony AVX-AV100 HU output is front channels are connected to the Arc and the rear channels connected to the NVX VAD 1000.4 , Arc 600.4 in the fairing running the ,Arc 6.5 602's Upper and lower fairing with JL C2-650 6.5 in the TP wired in parallel with the lower fair on the front channels on the Arc. The NVX VAd 1000.4 is running the JL audio 6x9 (c2-690-xt) in lids and inside of bags. the lids are connected to the front channel on the amp and the 6x9 in the bags are connected to the rear channels on the amp.
This is my setup above.
I just picked up a Rockford DSR1 and was wondering how to connect it to two amps. also, what will I put the gains and the frequency setting on the amps itself. I only been seeing videos on how to connect it the one amp and with subs and tweeters.
thanks,
thanks,
thanks,
thanks,
If and how you want your fade control to work will determine how to wire to the 2 amps.
I don't want to sound stupid, but what do you mean by the fade control would determine how I wire the 2 amps?
thanks,
thanks,
Then use the head unit rear outputs to channels 5&6 inputs of the dsp. Output channels 5&6 from the dsp to front inputs of the NVX. This will allow using the fade control to change the balance on the go.
All that being said, having fade control the way you have your setup configured, is probably a moot point. You should probably reconsider your amp, speaker and wiring strategy.
If you want to control front to rear fade on the go, through the head unit, you can. For example, if you want to be able to balance the bag speakers, you use the head unit front channels into the dsp on channels 1&2. Output channels 1&2 from the dsp to front channel input on the Arc600. Output channels 3&4 to the rear channel inputs of the Arc600.
DSM... you lost me when you said "Then use the head unit rear outputs to channels 5 and 6 inputs of the DSP".. I could be crazy here but I hooked my head unit RCA Front output to 1 and 2 input of the DSP.. then my HU Rear Output to 3/4 input of the DSP.. I could be wrong.. Please explain.. where you get 5 and 6 inputs on the DSR?.or maybe i had to much Titos last night..
