Best amp and 2 speakers $800 max, 19 RGS
With all the speaker testing here, whats new? I have a BT line leveler, looking for a amp to run 2 fairing speakers. Speakers dont have to be the loudest, but best SQ. Would like the speakers to be somewhat drop in, not cut up a bunch of plastic. Amp may be asked to power 2 lower fairing speakers at some time also. So what amp and 2 speakers for $800? Thoughts and suggestions.
IMHO some of the best SQ are from the hertz mlk 1650's.They are not the loudest and that is their downfall but have damn good SQ. If planning on possible lowers then the stinger spx 700.4 all day long for an amp. BTW you can add lowers for that bike for around $250 with speakers.
Those mlk's aren't cheap but if you research you can find them for $500 a set. The stinger can be had for $300 so that eats up your budget. I have not run the new wdx moto gen 2 but hear good thing from those. Others will chime in on speakers but the stinger amp is a truly solid amp for $300 as it is loud, warm and easy to install/tune. You already have the bt355 but you will need an amp wire harness. This one will work as it has a long enough - cable to run back to the battery.
This a good read.
https://www.hdforums.com/forum/audio...udio-coax.html
Originally Posted by big papa AZ
I read that. Lots of info, but the threads like that seem to wander all over, does this fit my XXX??? Too many question and answers!
If u just not sure, the safe play is the BT RG Premium setup paired with a NVX VADP. Without potential growth plans etc, just no way to help u look down the audio road.
T
Ur prob gonna have to provide some more detailed audio personal preference info to get good input for ur desires.
T
T
Have the same question as the topic starter - looking for a set of amp and fairing speakers to upgrade my SGS '19 for this season. Probably going to add two more (in lowers or in saddlebags), but later. Need something loud and have up to $1100 in my pocket. The problem is that I have to install in at my official HD dealer, so need something as easy to install as possible (like Boom!). May be J&M Rokker, or it is too much dollars for the brand?
