Warning
Originally Posted by gunslingersnation
Fill me in. Even with 100 watts to each of the 4 speakers, you don't think it would sound better?
Ok, I'm following you. So watching the Sonic Electronix amp dymo, it produced 270 at 2ohms. Obviously, I need to run less to the Fairing speakers. If I tuned it to 240 per channel, so 120 per speaker, that's still probably to taxing on the amp. Of I sold the speakers and went with something more sensitive like the Polk mm 6x9s or Hertz, could I run 100 to each speaker with reasonable results? Feel free to call me a dumb ***. This is like learning a new language.
One thing to remember, just because they got that output on the dyno doesn’t mean every amp will produce the same results. Input voltage, battery voltage, signal quality, etc all effect output of the amp. Without the proper equipment (dd1 or oscope) to see where the amp clips it’s best to stick to spec output.
BlackPearl#1
Audio Systems
04-12-2015 08:05 PM
Deepsouth251
11-10-2008 07:55 PM
