Need help with CV b52 amp an Line Leveler Install
I have a 18 RGS Got Infinity Kappas Mounted Removed Tank Ran Power an Ground wires hooked up remote wire to outlet,Now I Am Lost,I am Not good with electronics.Mount the amp on top of Headlight?I am clueless on the wireing,What do I hook up from head unit to amp?The line leveler I have has connecters for speakers not positive what to hookup.Any help with this install would be appreciated Thanks.
Clutched (03-15-2019)
Yea the line leveler is a Bt355,It has connecters for front Speakers Don't seem to be the same as mine?So you Hook line leveler to speakers an RCAs to amp,This is the Amp Out puts?How Do you Hook speakers to Amp An this would be Input Side?Thanks so much for any help.
Will look at it agin an see if I had the Right plug for speakers,When you say Output is wired to speakers that means you cut in to speaker wires before plugs?Thanks for the help.
no cutting required. You plug the line leveler into the stock speaker plugs that are attached to the harness not the speaker pod. Then RCA's run from the line leveler to the INPUT side of the amp. You then run speaker wires from the speaker terminals on the amp to your speakers
Clutched (03-16-2019)
benson1603
Audio Systems
02-09-2019 01:54 PM
