Mmats MD4110 or Stinger SPX700X4?
Yes sir Juice. You are correct, that would make them sing for sure. I had thought it about and researched the specs on Beyma's site on the Speaker and it shows a minimal impedance of 5 ohm.
https://www.beyma.com/en/products/c/...x200nd-n-8-oh/
Stric,
Everyone is running them this way so you get a 4 ohm load and the most out of your amps.
I have mine running bridged off a 1200.4 ch1-2. 300 watts each no issues, impedance will change through out. but if you put a ohm meter on them they will come out to 8 +/- .2 ohms each. Send them some power. if you like them now wait till you hear them with some more power.
Juice
Stricnine (03-06-2019)
Juice
Originally Posted by Juice
Stric,
Juice
Juice
Violently agree w Juice regarding the wiring strategy for ur Beyma CX. Bridged & parallel will be an entirely different sound stage.
T
Using the Stinger SPX700X4 amp with Hertz HCX165's in the fairing and Hertz SV165.1's in the lowers - any advide on how I should wire them? Both sets are 4 ohms each. Should I wire them a single speaker per channel, or HCX's on channels 1 & 2 at 4ohms and the SV's bridged in parallel on channels 3&4 at 2 ohms?
Thanks
Thanks
Thanks
Thanks
Juice
