2018 Street Glide Special Audio Uprade
Old 01-24-2019, 04:41 PM
Steezy's Avatar
Steezy
Steezy is offline
Originally Posted by marshallb
Smdh...
Not sure how helpful 4 letters can be as a response, but thanks for that
I didn't order anything yet so I can still change what I am doing. Was just asking why it is "junk"
Old 01-24-2019, 05:32 PM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Received 9,596 Likes on 3,245 Posts
All that you mentioned is overpriced and under delivers.
Old 01-24-2019, 05:41 PM
Steezy's Avatar
Steezy
Steezy is offline
Ok...that clarifies. Thank you. I am questioning the need for dual amps in this setup that Marshall suggested. If it is running a 700w 4 channel the second one seems unnecessary.
Old 01-24-2019, 05:51 PM
Steezy's Avatar
Steezy
Steezy is offline
Nevermind... I understand now the front speakers are rated at 400w so I would need to bridge the front one
Old 01-24-2019, 06:10 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
The second amp is for the horns.
Old 01-24-2019, 06:48 PM
Steezy's Avatar
Steezy
Steezy is offline
Thanks....missed the horns when I did the original Google search.of the items he listed
Do I need special grills in the front with those or will the stock fit back on?
Old 01-25-2019, 12:57 AM
angelrod's Avatar
angelrod
angelrod is offline
Thanks Sbates that answers a nagging question I had about the quality of the boom stock speakers
Also reading that I need an inline tuner or to have the stereo flashed due to signal, accurate?
So leads me back to suggestions for brands/models that I should use (or stay away from) other than RF.
this is what you need you can power up to 8 speakers if you like
Old 01-25-2019, 04:04 AM
travelingypsye's Avatar
travelingypsye
travelingypsye is offline
After looking at the spec sheet on that amp, 4x70@4ohm wont be enough to power 4 coax speakers let alone 8 unless I am overlooking something on the spec sheet. It might be enough for 4 pa style very efficient (96+sensitivity) and that is at best efficient but you will be pushing it to the max.
Old 01-25-2019, 10:41 AM
rochman's Avatar
rochman
rochman is offline
I am leaning on getting the Hogtunes 600 watts , 2 x 300 , fairing and bags , no lowers on my S G S , I am not reading any negative reviews as of yet but I have not Floated it on the Forum yet , that being said , Let Me Have It.
Old 01-25-2019, 05:04 PM
Steezy's Avatar
Steezy
Steezy is offline
Ok guys...reworked this and upped the budget a little because I figure it is a good idea to do this all at once instead of taking the fairing off multiple times.
BT4180 1440 W 4 channel amp
BT LL
Focal K2 Power 165KRC in fairing
Focal K2 Power 165KRC in lower fairing (running right in parallel and left in parallel between batwing and lower)
so that means I am adding the lower fairing and replacing speaker lids with aftermarket, going with coax rather than component but reduce the need to add an eq and extra horn amp.
4 speakers in front, 2 in back, and shouldn't draw too hard on the amp or mess with electrical.
Should be able to manage with the parallel and not increase the resistance out of range
Thoughts on this?
Quick Reply: 2018 Street Glide Special Audio Uprade
