Does anybody know if there is some type of mount for a mini amp to be mounted in the tour pak. I see alot of home made ones. I have the regular full trunk on RG. the amp is the same sizes that could go in the fairing, but I have one in there already.
What year RG?? What amp are you mounting in the Tourpack?? The reason I ask is you can mount multiple amps in the RG fairings.
Most amp racks that you can buy are made of plexiglas. With a little time and some measurements you can make a rack fairly inexpensive.
With that bike you should have no problems mounting multiple amps of that size in the fairing. You can mount 1 under the HU and 1 on the headlight assembly with room to spare.
sounds like a plan. is there anything I need to put under the amp.?
