Bridged ohm load
Old 01-10-2019 | 06:59 PM
Biggzed's Avatar
Biggzed
Default Bridged ohm load
If I wire a 4 ohm speaker bridged to an amp does the amp still see 4 ohm? I know if I parallel wire them the amp will see a 2 ohm load. Just can't find a clear answer on a straight bridged wiring. Amp I would be using is 4 ohm bridged stable (JL XD400/4v2).
Zach
Old 01-10-2019 | 07:13 PM
SBates08's Avatar
SBates08
Yes with a single 4ohm speaker bridged across 2 channels, the amp will see a 4ohm load.
Old 01-10-2019 | 07:27 PM
Biggzed's Avatar
Biggzed
Thanks. That's what I thought, just needed some reassurance.
Zach
Old 01-11-2019 | 08:30 AM
Juice's Avatar
Juice
Z,
I would still ohm out the speaker in question. even though the sticker says 4 ohm. Some manufactures are not as strict as others.
Juice
Old 01-11-2019 | 11:25 AM
marcodarq's Avatar
marcodarq
the act of bridging an amplifier is the combining the aspects of 2 channels into one channel. +from channel 1 and - from channel 2, in order to get more power, the amplifier's stability should be listed in the spec/instruction sheet and doesn't really change and should be be safe as long as your load is = to or a higher impedeance than the spec. if the amp is stable @ 4ohms, it's ok to put a 6 or 8 ohm load to it (lesser output) but not a 2 or 3 ohm load.
the wiring of speakers either in series or parallel will change the ohm load that the amp will see,,2 4ohm speakers in series = 8ohm load, 2 4 ohm speakers in parallel= 2 ohm load. check out this link,
https://geoffthegreygeek.com/multipl...s-share-power/
hope that helps.
m
Lastride (01-11-2019)
flhrbill
Audio Systems
09-24-2018 11:47 AM
Gambat
Audio Systems
01-05-2018 10:28 PM
deadduckflying
Audio Systems
12-12-2017 10:41 AM
Gnarl78
Audio Systems
04-04-2014 09:33 AM
Toliverpeterson
08-06-2012 08:47 PM
