Started stereo install on 2019 Road Glide Special
Old 12-25-2018, 05:48 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Hope u got a new search engine for Christmas!!! Lol!
Attached Thumbnails Started stereo install on 2019 Road Glide Special-photo593.jpg
Old 12-25-2018, 06:59 PM
h-d wrencher's Avatar
h-d wrencher
h-d wrencher is online now
Thanks tailwind! I even looked in my p&a harley catalog but nothing with that p/n.
Old 12-25-2018, 07:26 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Just jacking w ya my brother. I never have luck searching HD stuff online. Their site just no worky w my devices.
This part will be $10 well spent. I just don't cut into wires upstream of the harnesses, especially when potential warranty stuff is involved.
T
Old 12-26-2018, 08:00 PM
h-d wrencher
So I can just plug that 12v adapter into the harness on the bike, cut one end off of the adapter, add a spade terminal to the adapter, put a spade terminal on the other end of the remote wire and plug it in? No need for a ground?
Old 12-26-2018, 08:47 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
U need all three. Power, ground, and remote. The remote is akin to a light switch in a house. It either closes the loop to turn the light on or opens the loop or circuit to turn it off. The remote is tied to ur acc switch thus when the acc or ign is on the remote closes the amp power loop turning it on. Off opens the amp power loop.
*Source = my cave man electrical handbook.
T
Old 12-26-2018, 09:08 PM
h-d wrencher
Yeah I got that but I was referring to a ground on the 12v harness. The harness has 2 wires on it. Im assuming pos and neg. But do I just find the pos and run the remote wire to that and do nothing with the ground wire in the adapter?
Old 12-27-2018, 12:19 AM
Tailwind's Avatar
Tailwind
Tailwind is offline
Just the pos on that harness. When guys tap into the cig lighter for their remote power source they are only hooking up to the pos wire in that 2 wire bundle
T
Old 12-27-2018, 09:11 PM
h-d wrencher
Got it! Thanks again tailwind. Gonna work on it again tomorrow. I should have everything but the speakers.
Old 12-28-2018, 03:57 PM
h-d wrencher
Well I have all the wiring run and I got the line leveler today also. The line leveler has a place for 2 rca connections and 2 more plugs coming out of it. Do the plugs need to go anywhere or do I just need to run the stinger rcas from the amp to the line leveler? Not sure if there is a pos and neg on the rcas or if it matters which one goes where.
Old 12-28-2018, 04:03 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
The plugs will hook up the the speaker connections that you unplug from the pods. That is where your input for the amp comes from. If you look on top of the yellow label on the Line Leveler you'll see a red dot and a white dot. Red is for left, white is for right. The stinger has a diamond around the part you hold with your finger. One is red the other is clear (white).
Quick Reply: Started stereo install on 2019 Road Glide Special
