Speaker Baffles?
Speaker Baffles?
Anyone out there using these in pre Rushmore batwings? If so, do they work? What are your experiences with them? I've read all about using polyfil or dynamat (or similar). Will they have a similar effect? Seem to get decent enough reviews on Amazon. Total novice question here but, what if one were to wrap the speakers in a bit of polyfil, with these over top? Or will that get too tight in there and kill the sound?
They're cheap enough...and if nothing else, they would give a bit of water intrusion protection (should water happen to get between the inner & outer fairing) to non-marine speakers.
From their description: "Boom Mat speaker baffles maximize speaker performance by isolating the correct frequency responses while damping reverberation in the sheet metal and panel to frame resonance. Also forms a water tight protective shell to prevent moisture intrusion"
No issues with the added weight? I know these threaded inserts in the inner fairing are pretty fragile.
I think one of the things to be concerned with as far as protecting those threaded bushings goes is to not over tighten them. On mine when I put it back I use a T27 screwdriver instead of a socket wrench and put a SMALL amount of blue Loctite on the threads of the four T27 screws that go into the fairing to keep them from getting loose.
I haven't had any problems Lefty. I guess if you think about it those threaded inserts are designed to take the pressure of high speed wind blasts with shields of up to 15" tall. Also the amount of material needed to cover the inside of the fairing cap didn't seem to add much weight to it at all. I figure the downward pressure is being handled by the three screws up top at the shield and also the bottom portion on the fork covers as well.
