Am I missing anything before my install
12-07-2018, 01:07 PM
Take a look to see if I’m missing anything before my install. Any addition information will be highly appreciated.
Amp kit
AHB front signal speaker kit or LOC???
DSR-1
JL600/6
SD250.2
PRV6MR500
DD VO6x9
DD B3
thank you
12-07-2018, 01:42 PM
Where are you mounting the amps?
12-07-2018, 01:55 PM
12-07-2018, 01:57 PM
I’m assuming you’re on a street glide. Pretty sure you will need a different amp tray for the 600/6. Unless the stock one can be modified to fit.
12-07-2018, 03:29 PM
Are you going to bridge the 6x9's off the JL?
Zach
12-07-2018, 04:20 PM
Quote:
Originally Posted by
Biggzed
Zach
yes 6x9’s will be bridged
12-07-2018, 04:21 PM
Stuntmeat
I’ll modify the stock tray. The amp will fit.
12-07-2018, 05:32 PM
I'm not saying you have to, but are you planning on flashing the Boom HU?
12-07-2018, 05:58 PM
I didn't see any adult refreshments on that list!!!
Also wondering, can't you do away with the LOC and just run speaker level inputs on the DSR1?
12-07-2018, 09:18 PM
Sounds like a pretty damn solid plan...I'm assuming you'll use the SD for the horns... A channels 1&2 for the prv 6.5 and channels 3 4 5 6 for the dd 6x9.....that should be a great sounding 4 speaker set up
