DSR-1 - BT 355 Line leveler
Originally Posted by bazwp
Can I confirm that a DSR-1 does what the BT 355 Line leveler acheives or do I need to run both to get the optimun set using a Biketronics Amp?
I currently have both - but have not done the install yet.
Thanks in advance for the advice.
Not sure how the BT amp responds to a DSR so I strongly recommend calling BT Mike for the technical explanation, but I seriously doubt u would run both.
T
I have a 2180 amp and want to get the best out of my Hertz MLK 165.3 speakers (mid and tweeter set up). From what I read I wont get the best out of the speakers with the Hertz passive crossovers? But I now realise I have a two channel amp so a DSP (Rockford DSR-1) would not be effective as I only have two channel output?
Can I wire tweeters in some way that I can ditch crossovers and use DSP to set crossover and tune EQ for both tweeters and Mids
. Or do I need to upgrade to a 4 channel amp to acheive that outcome?
Bunker
Audio Systems
07-18-2021 10:09 PM
