Lower Faring Pod speakers Limited 2008-2013
Looking into speakers for my lowers. My bike is a 2011 Limited. My setup is very good but lacks bass.Have a friend who has been looking into pods speakers. My amp has plenty of power. I can tie pods in series to either the fronts or rears. Which is better? And what speakers in the pods gets me best bang and bass for my buck? Current setup is Kappa 62.11 in the front. 62.xi in the rear. AMP M4-3000D And Kenwood X998 HU. Thanks
You can't run in series with just any speaker. Whether you are paralleling or putting them in series, the speakers you're putting together need to match in specs as close as possible. With that being said, splitting 140 watts per channel (what that amp actually puts out at 4ohms) between 4 speakers will be extremely disappointing.
Sooo?
MA4-3000D
Category: Marine Audio.
3,000 Watt 4 Channel Class D Marine AmplifierMax Power (watts)3,000RMS Power 1Ω, 14.4V2 x 750RMS Power 2Ω, 14.4V4 x 375RMS Power 4Ω, 14.4V4 x 285
Product Description
- Compact 4.75” Chassis Design for Installation Versatility
- Splash Resistant Conformal Coated Circuit Boards
- MOSFET Power Supply w/ Audiophile Grade IRTM Transistors
- Military Grade SMT PCB Maintains Dynamic Performance
- 2-ohm Stereo & 1-ohm Full Range Operation
- Direct Short, Thermal, & Overload Circuits Protect Ampllifier
- 200mv-6V Low Level RCA Inputs
- High Level Input w/ Signal Sense Auto Turn-on
- Variable 12dB High Pass & Low Pass Crossovers
- 10-50Hz Variable 12dB Subsonic Crossover Protects Subwoofers
Have you considered moving tourpack speakers to the lowers and just running the stock rears off the HU. That would put all of your sound in front of you. If you ride 2up more than 1up your rears are covered up anyway.
Of course you can add an amp to run the lowers but depending on the cost you may be better off changing your rears over to 4ohm and parallel them with another set of 4ohms in the lowers.
Just my two cents but I would try putting all four Kappas up front in the upper and lower fairings powered by your existing amp. Then add a new set of 6 1/2’s and a new 4 channel amp of your choice in the tourpak. Use two of the new amps four channels to power the tourpak pods and save two for 6x9’s in the lids of you still want more bass at a later date. Also the Harley tour pack bass ports would really boost the bass of 6 1/2’s in the rear pods letting them breath more in those tiny enclosures. In the end, of course, most of your bass will be left behind you for your wife to enjoy on her bike, lol
If this amp is truly 1 ohm stable you could run 2 fairing and 2 lowers in parallel on channels 1 and 2 and your tp pods one each on 3 and 4, but if it were me i would be calling their tech services dept to make sure for sure that the amp can run at 1 ohm stable. it will be very cool if it does and I'd like to see a dyno run on it and hear the SQ. Let us know what tech support says about it being stable at 1 ohm.
marco
this amp seems like it's kinda similar to the way the brazilian amps are set up with the multiple ohm specs runnging so low,,,make sure that you CONFIRM!!!!
marco
Hummm?
So another thought. As stated. Move all 4 Kappas to the front faring and lower faring. Now the HU has a sub output. What amp and what speakers would work well in the rear pods. Being used as a sub? Do I need to run a RCA to the rear? wiring is got me perplexed. I would definitely add an amp. Speaker wire already ran to the rear. Amp suggestions? Thanks
