Is this essentially right as far as wiring?
As long as you have the focal in 2 channel input, then all 4 outputs will be fine without a rca y splitter but there is no fade from front to rear. Just 2 speaker setup? If so just run the components off the front 2 channels to the crossover and let the crossover separate the woofs and tweets. The rear channels are not in play. If you are trying to bridge that focal to use on just the fairing then that will be WAY TOO MUCH power to those 1650's.
This is a pic of input connector that came with the amp.
If I am following correctly, I should just use the channel 1 and 2 plugs and make sure the amp is set on 2 in.
Both these RCA's and the BT355 are females, so will have to get a male to male to mate them.
