Just offering up, what is mostly 2nd hand opinion... Gonna be tough to replace your Focal with similar power and get something warmer, ARC Moto 600.4, BT 4250, get close to the power but the gurus have told me they are not considered "warm" Warm and JL amps get referenced together pretty often, but your going to give up some power JL 400/4 or 600/6 I've heard will fit on the tray, but don't recall the 600/4... Another thought would be to add a DSP to with your Focal I think you could warm it up a bit thru equalization...
azmaniac thank you,
a picture is worth a 1000 words. Im buying the JM amp tray, then i can add a couple of JL or GZ micros bridged and DSP.
the never ending hunt
azmaniac thank you,
Yes sir that is sitting on a Jm amp tray...I only used the bottom part of tray
