trouble shooting help
A buddies bike is randomly cutting out sound from all speakers. the bike has 3 amps, a DSR1, and 8 speakers with 4 tweeters. it happens at all different volume levels and seems completely random. He swapped the head unit out with no change. it also has a metra axxess module for handle bar controls. any help is greatly appreciated
Depending on how he has the amps wired and speakers in play, the setup and amps may be going into protect mode. If he has 2 ohm speakers inline with 4 ohm or trying to bridge 2 ohm speakers, that will cause an unstable setup for any amp. Let the forum know just what the setup consist of and how it is wired.
I fixed one awhile back that was doing that, I found that the plug on the DSR wasn't making good connection and the slightest vibration would make it lose connection. I have read threads where others had the same problem, and there solution was to use a small zip tie around the plug. I think that is one of the problems they are addressing with the new one they are working on.
