Soundstream TN2.600
Soundstream TN2.600
Has anyone tried this amp? It`s rated 200 rms x 2 at 4ohms and 300 x 2 at 2ohms. I would like to wire four vo 6x9`s to it.
https://www.ebay.com/itm/SOUNDSTREAM...09e4%7Ciid%3A1
some of the product description doesnt make sense to me, if i were you i would go to soundstream homepage and check the specs there
I’m not familiar with that soundstream amp but another option would be a Soundigital sd800.4D evo 2ohm. You could bridge/parallel 4 speakers and they would get 200w each if I’m understanding the specs correctly. Not sure if size is a issue for you or not. You would need xover control by head unit or dsp.
[h1=start]800.4D EVO 2Ω
Power @ 12.6V @ 1Ω: 4 x 200 W RMS
Power @ 12.6V @ 2Ω: 4 x 110 W RMS
Power @ 12.6V @ 4Ω: 4 x 61 W RMS
Bridge Power @ 12.6V @ 2Ω: 2 x 400 W RMS
Bridge Power @ 12.6V @ 4Ω: 2 x 220 W RMS
800.4D EVO 4Ω
Power @ 12.6V @ 2Ω: 4 x 200 W RMS
Power @ 12.6V @ 4Ω: 4 x 110 W RMS
Power @ 12.6V @ 8Ω: 4 x 61 W RMS
Bridge Power @ 12.6V @ 4Ω: 2 x 400 W RMS
Bridge Power @ 12.6V @ 8Ω: 2 x 220 W RMS[/h1]
800.4D EVO 4Ω
I am currently running one pn4.1000d. The front channels are powering four 8 ohm mmats and two b3 horns. The rear channels are powering four vo 6x9`s. My system sounds loud and clear but I want more power to 6x9`s so I figured the easiest way was to get a two channel amp and wire 2 ohm stereo. This will also allow me to wire set of mmats in parallel with horns so I can wire lowers on separate channels so I can dial them in better. Basically Soundstream amp for fronts and two channel amp for rears. The soundigital amp looks to be less power than the soundstream at 2 ohms. Any suggestions on a good two channel amp that can power 6x9`s?
I would put that SD 100 watts @4ohm over the 140 watts @4ohms any day. Hell, the JL 75watts@ 4ohm would be better with the speakers you mentioned.
Juice
Delgado130 (10-18-2018)
