Looking to add a set lower fairing speakers
Old 10-08-2018 | 12:27 PM
470004's Avatar
470004
Default Looking to add a set lower fairing speakers
I am considering on adding a set of Lower Fairing Speakers to my 2013 TG. Harley's Part & Accessories catalog states I need to purchase a Boom! Audio Speaker Expansion Kit; $569.95 to do this. The radio is stock Harmon Kardon with a HD's Boom! power ampifier. Is there a way to connect these speakers without the Expansion Kit? At this time, I am not considering changing out to a better aftermarket audio system since I am a fixed income.
Old 10-08-2018 | 12:39 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
When I decided to start adding amps on my 2010 (which I think has the same radio as yours) I sent my head unit to Iron Cross Audio and got them to add standard low level RCA outputs to it. Once that is done you can add about any amp that will fit.
If you did that you could get a small amp to run off of the RCA outputs to run the lower speakers. I think it is a little over $100 to have front and rear preamp outputs added. If you do decide to go that route I would definitely get both front and rear.
Others may have some ideas as well. I just know that setup worked well for me. I am running two amps and eight speakers off of the stock HK head unit. I like my AVC
470004 (10-22-2018)
eross318
Audio Systems
11-04-2016 12:14 AM
tpb857
Audio Systems
01-12-2014 09:04 AM
Crusader45
07-26-2013 09:01 PM
DeeGzNuTz
08-15-2012 11:40 AM
Sincecrazy
12-11-2008 07:55 AM
Quick Reply: Looking to add a set lower fairing speakers
