Advice on what to buy next 18 sg
So I started off with a jl mx280 bt355 bridged into hertz 165.3 Pro. In my option the bt355 was lacking mid to low end so played with adjustments. Got it sounding good but in my path to audio perfection I bought a dsr1, removed the bt355 and used a American hard bag speaker level resistor harness. I feel the sound is great using the signal processor but maybe a touch too much high. Started playing with the bandpass crossover and the dsr1 wigged out, made a high pitch squeal ended up frying the tweets in the two week old hertz.
So time to start over.
I got a set of lower with pods, thinking hertz st25 horns where mirrors went and 2 pair of prv mids(fairing and lowers) . Confused as to which prv to buy, buying a arc 600.4 amp but feel I'm gonna need more power. Anyone try any of this? Should I just get 2 pairs of arc 602's and abandon the super tweeter idea? Can I run the 600. 4 and mx280 in fairing?
I should have got the road glide 😅 as I'm getting a bit addicted to finding the best audio and need more room!
Thanks
Thanks
Thanks
Thanks
2 amps in the fairing is very doable depending on the amps used. As for the ST25s mounted were the mirrors are on the inner fairing the STs are to deep and you will have to grind the magnet down to get the outer fairing to fit and modify the speaker pods.
I think I'm settled on a game plan. Bt pod eliminator brackets, 2 pair of prv 6mr500 , arc 600.4, dd v03's in speaker grill, keeping mx280 for tweets and running prvs off arc. Eventually doing dd vo 6x9's and another pair of horns in bag lids. Which I may have to go to a different amp at that point .
My only question is should I make one of my pairs of 6.5's a aw 6.5 for its lower response?
Babyboy thanks for all the help.! I'm gonna come by and hear what you got cooking this weekend.
