Single pin plug
Single pin plug
I have a cardo attached to my helmet and would like to use yhe bikes stereo and pipe it into the cardo so it plays in the speakers in my helmet.
Is there an adapter plug I can plug into the bikes multi pin outlet, then plug a single pin wire (similar to what plugs into players or cell phones) into it and the cardo?
What bike? If it is an Ultra Classic Aerostitch makes an adapter that plugs into the seven pin port and has a standard 3.5mm stereo socket on the other end. I have tried one and it works well. The only thing I noticed is if you try one of the new fangled four conductor plug headsets with a microphone it gets wonky. When I used a set of standard earbuds without a microphone (three conductor plug) it worked perfectly.
glideridemike (09-18-2018)
glideridemike (09-20-2018)
